跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Blurred camera after replacing back glass
Hello everyone,
Probably not done the best repair work of my life here, and I know there are other methods of changing the iphone X back glass, but I used the “Heat-gun” method
Having a severely cracked back glass, Using a hot air gun to remove the adhesive I was able to remove all of the glass and remaining fragments WITHOUT touching or moving the camera lens cover…. the issue now that trying the camera app (or any that use the rear camera) it seems to focus in a blurred manner.
My question here would be…. what is the most likely cause? I would assume the camera assembly may have overheated and now caused the blurr ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Yes, you have fried the rear camera. it should be removed as very sensitive to heat.
这个答案有帮助吗?
得分 0
添加一条评论
I have this problem too, so how you solve that? Change the new camera?? :((
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kristian 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 21
总计 1,936
