跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
Loop mode after changing battery
Replaced my iPhone 7 battery yesterday. I’ve done this in the past with my old iPhone so I felt fairly confident. Followed directions and all seemed to go smooth. When powered back on, my phone is stuck in loop mode and won’t fully start up. Rechecked all my cables and all seem fine. After further investigation I realized my phone would fully start up and work if I left the home button cable unplugged. Home button obviously doesn’t work, but everything else works fine. Any ideas what my issue may be??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
My phone charges up and works fine without the shorter home button cable plugged in (other than not having a home button). I’m actually using it right now. It just won’t start up when home button is hooked up. Does this point to an issue with the home button or is it possible that it will boot up if I leave it in loop mode for a while?
完成的
添加一条评论
2个答案
最有帮助的答案
From your case it would be either one of the following:
The home button flex cable on the home button itself has been torn. Extremely unlikely if the metal bracket for the home button was not removed from the screen.
The most likely cause is a microtear on the screen cable itself. It'll be the smaller cable specifically coming from the screen and not the front camera.
The part where it tears is behind the metal shield that goes on top of the back of the screen.
Hopefully just the screen needs to be replaced rather than the home button which if it is the latter would required to be replaced by an aftermarket one with no touch ID.
这个答案有帮助吗?
得分 1
1条评论:
Ben is right. This is a common problem after removing and replacing the screen. If you leave it long enough it should boot and you can confirm.
完成的
添加一条评论
Check the parts near the battery connector. Be sure that battery is charged or connect to battery connector properly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
CHRISTRUSCH88 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 27
总计 203
