跳转到主内容
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
Clothes still wet after spin cycle-no error code
Washer does not seem to go into "high" spin cycle and leaves heavy item wet at end of cycle. Tried to extend spin cycle, and tried to re-run entire wash cycle with no improved results.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
The first thing I would try is to use a smaller, lighter load. The load may be so heavy it can't get up to speed.
完成的
I ran the small bathroom rug back through wash cycle with other items & it finally spun correctly. Thanks!
完成的
添加一条评论
2个答案
已选择的解决方案
This can be caused by any one of these:
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Let us know if it starts happening again for more detail.
这个答案有帮助吗?
得分 2
添加一条评论
The washer was working fine then a pop and rubber burning smell. Now it has the same symptom as above
and I only have a towel in the washer and it does not get to a high speed spin. It toggles back and forth to a relative slow spin for a little stops and then changes directions and keeps doing that and then finishes as if all went ok
Thanks Stan B
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ybsul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,774
