跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Face ID issues after battery replacement (move a little higher/lower)
So after replacing my battery Face ID is no longer able to register my face always saying to move the phone a little higher and then to move the phone a little lower in a loop. I believe the issue is the dot projector. Heres what i’ve tested so far:
  1. putting the original battery back in
  2. cleaning all connectors
  3. reseating back cameras
  4. taking out the sensor module containing the front camera and putting it back in
  5. reseating and cleaning everything on the sensors connected to the screen
  6. called apple support who ran diagnostics and said that they didn’t see any issues with the hardware
  7. cleaned the dot projector with isopropyl alcohol
The front camera and back cameras still work as well as the proximity sensor and ambient light sensor. I also used an old camera to see that the flood illuminator was lighting up. The only thing that refuses to light up is the dot projector. Thanks for the help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Rewa has just recently made a video on this. It cannot be fixed by a 3rd repair. You have to go to Apple but even then they won’t work on the phone because you swapped the battery.
这个答案有帮助吗?
得分 0
1条评论:
Pls share the video link
完成的
添加一条评论
Here comes the latest dot projector repair technique for Face ID move iPhone a little lower/higher
iPhone XS Max Face ID Not Working Fixed - Dot Projector Repair
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Taylor Vandenberg 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 50
总计 7,329
