跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
Contemplating on changing the motherboard
Will removing the motorboats of a blacklisted phone make it able for use again
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
6条评论:
Could I buy a Vodafone motherboard and put it in my phone so I could use the Vodafone carrier on my phone
完成的
Yes you could by a vodafone motherboard but with this type of phone they are not locked to a carrier in australia. So you would be able to use any one you choose to.
完成的
So if I bought a Vodafone motherboard for my sprint locked iPhone and changed the motherboards I could u law the carrier normally
完成的
*****use it as normal
完成的
yes that is correct.
完成的
显示更多的1条评论
添加一条评论
1个答案
When a mobile phone is blacklisted, only the IMEI is meaning all the parts around the motherboard are still good for use. Just keep in mind the motherboard is the phone so prices will be pretty high just for a board but to answer the question, once changed will work fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylan Cresham 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 55
