跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
How can I revive a dead laptop for a friend
Over the weekend a friend of mine and his son decided to upgrade Mom’s laptop. They installed Crucial MX 500 1TB SSD and 16 GB of Crucial memory. After completing the upgrade the laptop failed to restart. They tried everything at the Apple support site, and nothing . They undid the upgrade, reinstalled the old parts and the laptop was still DOA. Mind you the laptop was working fine before the fiasco took place.
Now it’s in my hands. I really don’t want to let them down as they can’t afford a new laptop. Any help would be greatly appreciated.
P.S. The light on the charger is barely lit when plugged in and charging.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
To answer your main question, that depends on your skills when it comes to logic boards repair, a faint green magsafe light points to a board issue that may easily involve shorted components and/or a faulty first stage power rails or charging circuit.
这个答案有帮助吗?
得分 4
6条评论:
@stealth576 Did you disconnect the battery before the upgrade???
If not then i think you shorted a compontent
完成的
@arbaman yeah, turns out he and his dad decided to DIY a hard drive and memory upgrade. Had never repaired a laptop or anything electronic before. End result was a fried mainboard among other things. Was able to repair it with spare parts I had lying around.
They didn't learn their lesson though, had to repair two more macbooks they tried to upgrade several week later.
完成的
@beanman56 You didn't read the question correctly. I received the laptop after the Macbook owners failed upgrade attempt. It's common sense to disconnect the battery prior to working on any laptop.
I was able to repair the laptop and complete the upgrades for him.
完成的
@stealth576 So what do you need help with now??? :|
(By the way i know what i am talking about i am on the same kind of MacBook pro)
完成的
@stealth576 - If you're set don't forget to score the answer and accept it, I'm sure @arbaman would appreciate it!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
John Serrano 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
