跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
iPhone 7 vertical lines
Hi all
Have here an Iphone 7 which was dropped in the bath (kids!!) took it apart and cleaned motherboard amongst other parts with osyprinal and replaced the screen, all cam back to life and no issues for a few months, until now she dropped the phone which did not damage the screen in any way, however the screen is showing lines now, touch still works, I have changed the screen to see if that would sort it out but still with the same issue, see attached.
Any pointers would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Remove any power from the phone (including the battery) it could be that there is corrosion in connectors due to the water or it would be you damaged the pins when you plugged in the screen, corruption can be cleaned with alcohol and a toothbrush and if there is a bent pin you could try ending it back but most likely you need to replace the connector which required soldering and it’s a job for a professional
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
colin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 11
总计 67
