跳转到主内容
Repair information and troubleshooting for the RCA Voyager III, a 7 inch budget tablet that uses Android 6.0 OS and can access the Google Play app store.
34 个问题 查看全部
My battery won't charge.
My tablet was stuck in fastboot mode. Now it won't charge. When it's plugged in the battery icon with the lightning bolt shows but it doesn't move. The screen flashes on and off. Holding the power and volume buttons only makes the screen flash. It doesn't bring up recovery mode. I've tried unplugging the battery but it doesn't change anything. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
laurie  check your USB post as well as your charger to make sure that all of those are working okay. I’d start with a new battery since part of this can be caused by a bad battery and if nothing else it will give you a known-well starting point for further troubleshooting.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your response.
完成的
添加一条评论
添加你的答案
laurie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 147
