跳转到主内容
Fourth generation of the Toyota Pickup.
49 个问题 查看全部
Does the 1988 toyota pickup have a check engine light?
Does the 1988 toyota pickup have a check engine light. I went to get it smogged, the smog tech said he couldnt do the test because my check engine light was not coming on. My boyfriend checked for the check engine light but couldn't find it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The check engine light should flash when you turn the key to start.
这个答案有帮助吗?
得分 0
1条评论:
Shine a flashlight towards the cluster to see if it will appear, it might be in the row of IDIOT lights under all the gauges, look under the fuel gauge on the right hand side ??
完成的
添加一条评论
添加你的答案
Melissa Fink 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 197
