跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 个问题 查看全部
no usb
USB not working at all. mac fires up but not a peep out of the USB
tried plugging different USB devices in which have lights on them but doesn't seem to be power available
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
If one of these answers fixes your problem, please go to that answer and hit the "accept" so that we can remove the question from the unanswered list. Thanks so much.
完成的
添加一条评论
3个答案
已选择的解决方案
According to what system you are running different IOUSBFamily are needed. You can look it up here for a detailed decription of the problem and which files are needed:http://developer.apple.com/hardwaredrive...
or
just reinstall your system and the updates.
Debug releases of the IOUSBFamily kernel extension are used to provide information about USB device and interface detection, driver and interface matching, driver loading and information generated as a result of normal and abnormal conditions.
Unique debugging versions of the IOUSBFamily kernel extension are available for the different Mac OS X releases. It is important that you install the correct version of the IOUSBFamily kernel extension or you might find that the system will panic during startup or that your USB keyboard or mouse may not function properly.
这个答案有帮助吗?
得分 4
添加一条评论
Looking at the teardown guide the USB ports are soldered to the logic board. Therefor my first step would be to run disk repair. If that didn't help I would make sure I had a good backup--reformat the drive and reinstall the OS. If still no luck you may be looking at a bad logic board. I usually recommend getting an appointment with a Mac Genius for confirmation before buying a expensive part. Ralph
这个答案有帮助吗?
得分 2
添加一条评论
If you go to /System/Library/Extensions/ do you see IOUSBFamily.kext ?
这个答案有帮助吗?
得分 1
1条评论:
just looked in Extensions folder IOUSBFamily not there
完成的
添加一条评论
添加你的答案
mat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 9
总计 1,960
