跳转到主内容
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
368 个问题 查看全部
Why is my system overheating?
I've had the system for a few years and until last week it has never been cleaned before. The fan was loud but not to bad. I never had any issue out of it. Last week I had disassembled it and gave it a very good cleaning. The system was packed with dust. Very dirty. I used canned air to get dust out of small spaces and I cleaned the fan very well. I also replaced the thermal paste with Noctua NT-H1 Pro-Grade. I reassembled it and made sure everything was connected and placed properly. It started no problem. I could watch movies on apps and download games. Once I started a game disc the fan got really loud and shut off and I heard a few beeps. It did that 3 times. I tried a different game and it didn't turn off but the system literally sounding like a jet about to take off. Now I can play games but the fan is still very very loud and it doesn't sound good during gameplay. When I look up the symptoms all I get is it could be dust (No dust at all and replaced thermal paste) or the fan doesn't work (fan is definitely blowing out air) does anyone have an Idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Double check if the clamp is installed correctly. If it is installed upside down it will not give enough clamping pressure so that the heatsink cooler gives enough pressure on to the APU processor.
Also check if thermal pads on both sides of silver metal plates are present. Any missing or very misaligned will trigger the overheating warning.
这个答案有帮助吗?
得分 1
添加一条评论
it sounds like you know your way around a system pretty well. It’s odd that you would be having those issues even though followed proper procedures (Assuming everything was done correctly). I know this might sound odd. Try to reapply thermal paste.
如何涂散热膏
As much you probably don’t want to go through that again. I’ve repair many PS4’s but never had any do that
Thermal Compound i use is Arctic MX-4 (2019 Edition)
If you figure it out im really interested on what the reason is
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriel Wallace 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,219
