跳转到主内容
After a fall mac running slow and fan is really loud
Hello, after a fall my mac is running super super super slow and the fan is in high speed and really loud.
I already opened the mac, the fan is clean.
I also tried to reboot it and settle MAC OS X LION, after 24hours of instal at 99% the mac says it is not possible to download the complementary component for the install of MAC OS X.
I also tried to change the harddrive
Do you have any idea ? Any recommandation ?
Thanks a lot :D
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Well, fan is just a fan, no brain, does what the system tells it to do. Troubleshooting a Mac after a fall may involve all and everything as a fan running full speed may be caused by a faulty sensor as well as the SMC that is the big boss of sensing and power handling. You can try disconnecting all parts connected to your Mac logic board, battery included, except keyboard/trackpad for turning it on/off and verify if anything is causing the issue. If that stops CPU throttling and full speed fan, reconnect cables one by one until you find the faulty part. If full speed fan is still there you’d probably have to replace the board or get it repaired.
这个答案有帮助吗?
得分 2
3条评论:
Hello Arbaman, thank you for your reply ! I will try that tonight and let you know :)
完成的
I did what you said, the issue was from the camera. I removed the cable from the camera and the fan is now perfectly fine and the speed of the mac also ! I would have never guessed that the camera could be a problem ! Thank you for your idea !
完成的
@anaisrqr Brava, it was worth getting your hands on eventually! If you don't use much the camera it would be easier to think of a webcam, as that is a troublesome or relatively expensive repair.
完成的
添加一条评论
添加你的答案
Anaïs 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 325
