跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
iPhone 7 Plus No Service after Charging Port Replacement
I have an iPhone 7 Plus which I need to replacement the charging port. So, to save time and make sure the charging port works, I always test the charging port by connecting it to the board and also connecting the reception signal connector to the board as well. Now, I’ve tried over 4 different charging ports (all from the same company) and I keep getting ‘‘NO SERVICE’’ on all of them.
Does the charging port need to be completely installed and screwed in for the service signal to work? Or should I be getting reception signal regardless?
When connecting the original OEM charging port back, I have no problem with signal reception.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I would think it needs to be grounded.
完成的
添加一条评论
1个答案
Charging Port has GSM Antennas and need to be placed well to get signal, if your original Flex Cable is working Fine (Phone Signal), there is a change that all charging ports from that company are bad. If you ordered a lot from China sometimes they did not solder the antennas well.
这个答案有帮助吗?
得分 0
2条评论:
I should have been more specific sorry. The OEM charging port reception signal works yes, because it's intalled properly. But when testing the other charging ports, I only connect the main charging port connector to the board and the reception signal connector, the actualy charging port is not properly seated inside the mid frame. (this save me time, just to see if the charging port is working) So my question was, does it need to be properly installed for the reception signal to work?
完成的
Yes, it need to be placed with screws, main screws are those next to charging port and one next to speaker. Silver points that touch the bottom housing.
完成的
添加一条评论
添加你的答案
Jason Savoie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 369
