iPhone 7 Plus No Service after Charging Port Replacement
I have an iPhone 7 Plus which I need to replacement the charging port. So, to save time and make sure the charging port works, I always test the charging port by connecting it to the board and also connecting the reception signal connector to the board as well. Now, I’ve tried over 4 different charging ports (all from the same company) and I keep getting ‘‘NO SERVICE’’ on all of them.
Does the charging port need to be completely installed and screwed in for the service signal to work? Or should I be getting reception signal regardless?
When connecting the original OEM charging port back, I have no problem with signal reception.
I would think it needs to be grounded.
由 Chris Stables 完成的
