跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
iPhone X Boot loop after water damage
Hello guys. I have had my iPhone X for 2 years now and I have taken over 100 pictures underwater with no problem. Three days ago I dropped my iPhone in the bathtub for no more than 2 seconds and got it out. Feeling safe that the phone is waterproof I left it on the shelf and an hour later I looked at the phone at it was bootlooping and having all kinds of strange artifacts on the screen.
I took the sim tray out and left it next to a fan. On the other day the phone wasn’t turning on at all. I left it in a bag of rice for 2 days(I didn’t think it would help). I took it out 2 days later and the phone was showing that there was no battery and still had artifacts and screen flashes.
I removed the screen and tried to dry the phone with a heat gun. After that the screen was fixed and there were no more screen artifacts, but the phone is now bootlooping.(5 seconds apple logo, 5 seconds black screen) until the battery is empty and then it shows the no battery animation again. Any idea what I need to replace or do in order to get the phone to boot, or is the logic board fried ? Thank you.
Update (11/19/2019)
Hello guys. The phone is almost fixed. I cleaned the taptic engine connector and the phone booted. I have 2 remaining problems:
  1. The taptic engine makes very strange metal noises. Most likely it is damaged ?
  2. When heating the phone I have managed to melt the front camera and the infrared camera. All other sensors are ok and there is no error for face id. I know the front camera can be replaced without problems, but will replacing the infrared camera break Face ID ? I know the flood illuminator and the dot projector cannot be replaced, but what about the infrared camera ? Does it have a chip with logic board data ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
How hot was the heat gun, and was the battery still installed when you heated it?
完成的
@reedcrosby
Very hot and the battery was installed, but I never pointed the heat gun at the battery.
完成的
添加一条评论
3个答案
已选择的解决方案
Open charging flex and power on iPhone and check most have vibrator circuit issues.
这个答案有帮助吗?
得分 1
添加一条评论
watch this video . will give u an idea how to fix that. https://youtu.be/BU95TBsJxM8 https://youtu.be/BU95TBsJxM8
这个答案有帮助吗?
得分 1
添加一条评论
Hello I have the same problem.
totally you find a solution ??
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nikola Hristov 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 887
