跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
569 个问题 查看全部
Do I need a new hard drive?
Ok so i think I damaged my ps4 by leaving it on for too long and it’d over heat. The issues I’m having are the ps4 shutting down when I try to load any game and getting a message saying the software is corrupted. I’ve tried many times now rebuilding the data base and even initializing it as well but still nothing. Do I need a new hard drive? Or anything else?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
do I need a new hard drive
完成的
@Micheal franklin Why? what are the issues? The same as the OP? Follow the answers provided.....
完成的
Yeah i think you do,
I think you should get a NAS drive, Those last longer and can be on for longer
https://www.amazon.com/Seagate-Laptop-2-...
Also Please check this out
tech bois
TOZO-T10
完成的
添加一条评论
2个答案
最有帮助的答案
Hi @ramirezchris64
If there are no important data on this hard disk, you can remove it and test it on a PC.
most hard disk manufacturer provides their in house software to test HDD.
you can download and test it.
Since SSD (Solid State Drives) price are reasonable now, I would suggest you to get this instead, which I recommend for replacement, as for reliability and speed. Brands like samsung, micron should be good.
I will also get this enclosure for standby.
https://www.orico.shop/en/orico-hard-dri...
这个答案有帮助吗?
得分 2
1条评论:
The one I recommend to check hard drive health is hard disk sentinel.
If the drive reports any weak or bad sectors on the program the hard drive should be replaced.
In the rare case that it comes up with just 1 weak sector this can actually be reused without needing hard drive replacement.
完成的
添加一条评论
Yes, you need a new HDD, preferably solid-state. I’m going through the exact same thing and the best thing to do is take out the bad HDD and leave it alone until you can clone it to an HDD of the same or bigger size. Chances are, the new HDD will inherit the corruption, but a database rebuild should do the trick, although you may lose some data in the process. Make sure to back up all your data beforehand, if you can.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ramirezchris64 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 18
总计 2,006
