跳转到主内容
The TI-89 Titanium is a graphing calculator developed by Texas Instruments (TI) and released in 2004. TI-89 calculators include a computer algebra system that allows the symbolic manipulation of algebraic expressions.
3 个问题 查看全部
Original TI-89 enter key not working
I have an original TI-89 which is kind of corroded on the inside. The enter key worked just fine a little while ago, but after taking it apart and carefully back together, all the other buttons work, just not the enter key. Any ideas on repair? Should I just get another one?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I don't have a definitive answer, however this is off the top of my head: If it stopped working right after you put it back together, I'd suggest taking it back apart and seeing if you simply didn't put the enter key back together properly. You can use this guide if you need: TI-89 Titanium Power Button Replacement I'd highly suggest cleaning the battery corrosion while you're at it (there's many guides online if you need help with that)
这个答案有帮助吗?
得分 1
1条评论:
Alright, I'll try that.
完成的
添加一条评论
添加你的答案
kubagurPL 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 10
总计 723
