跳转到主内容
惠普台式机维修指南。
DMI tool for 00A system board error
Is there a HP DMI tool for 00A system board error. Missing product ID info causing aboot up error? I have all this info to enter into something… Thanks
Update (11/17/2019)
Mike:
Thanks for your quick reply. I have an HP Pavillion 510-a010, bought it new in 2016. I will try your solution and I have jumped the CMOS jumpers but that did not work. Is that what you are referring to? I also think the 4 pin molex cables may be an issue but we’ll see. Thank you, Stewart
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Unplug power supply.
Press power button until fans stop.
Reset BIOS. You don’t state which HP desktop model.
There is usually a jumper to short to clear BIOS to factory default. Often near Front Panel connectors.
Plug-in power cable and switch on.
How did it go?
这个答案有帮助吗?
得分 3
2条评论:
Do not turn on the pc while the jumper is shorted
完成的
@captainsnowball Thanks.....Is this the CMOS jumper pins next to the password jumper pin? Andhowdo I 'short it'? And why? HP 510-a010 model
完成的
添加一条评论
添加你的答案
shaimson7 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 33
总计 5,715
