跳转到主内容
The Huawei Watch GT is a long-battery-life outdoor smartwatch, which features GPS, TruSleep, monitoring and TruScreen technology. Released in 2018. The 42 mm and 46 mm options share the same model number FTN-B19.
8 个问题 查看全部
Top Button Stopped Working
Hi,
I went swimming with my watch on and it started to turn off and on again at intermitant times. That said, the watch now works ish, the top button wont work and if i want to turn the watch off it does so but 2 seconds later it switches back on again.
I need to know if i can fix this or is it time to buy a new watch?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you’re on the brink of getting a new watch it’s always worth taking a look inside the GT to see if you can find the issue and maybe fix it.
Try our opening guide for getting in. Sometimes a good clean with isopropyl alcohol and proper re-sealing does wonders. Good luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matthew Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 48
总计 1,427
