跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
LCD backlight connector issue (darker left side)
Hi all! I have a 27” iMac mid 2011.
It has a known LCD backlight connector fault. I already tried the re-soldering the left side connector but messed up the connection points while soldering the wires to the LCD’s LED backlight board. the connection points on the LCD for the LED’s not holding the soldering anymore ):
So, is there any way around to solder the power cable for the LED backlights from the iMac to connect directly? I couldn’t find any tear down guide for the LCD panel.
Thanks in advance for any bit of help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Mücahit Kahraman post some good pictures of your attempted repair etc. with your question. That way we can see what you see and hopefully find a solution for your problem. 在已经存在的问题里加入图片
完成的
Added some photos to make it more clear.
完成的
Mücahit Kahraman post one that is zoomed out so we can see the general location of the botched area.
完成的
添加一条评论
1个答案
最有帮助的答案
That looks like you are having a lot of fun, last time the moderator remove a comment with links so i have to explain it to you. I found the schematics basically is a LG Display the model is LM270WQ1, and has a led strips. that connection goes to the led strips you can find some guys on google (I can’t share links ) that are replacing the led strips from the display panel. Now looks like you are doing crazy things there, make sure that your Backlight Power supply still working and does not have any blow fuse.
https://gerrysweeney.com/apple-imac-27-d...
https://forums.macrumors.com/threads/is-...
https://www.avnet-integrated.eu/fileadmi...
这个答案有帮助吗?
得分 2
2条评论:
@conlledo you absolutely can share links and are encouraged to do so :-) Only thing we ask for is that you do not link to your own business etc.
完成的
@oldturkey03 got it, i did not remenber what i shared, i think was a ebay product, but i got it
完成的
添加一条评论
添加你的答案
Mücahit Kahraman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 239
