If I can, how do I replace the HDD with a SSD
If i can, how do I replace the HDD with a SSD in my Time Capsule? After all an SSD would be much faster.
Hope this is helpful!
Regards,
Lewis
Admin
这个答案有帮助吗?
Great thank you!
Great but how do I connect an SSD to the HDD connector. No doubt I need a convertor. But what is available and what do I need pls
Replacement HDD larger than 2 TB?
May be this helps. SSD will improve the speeds provided you have SSD on your laptop/desktop so that it can send data QUICK.
also any wireless backup will depend on your wireless router.
这个答案有帮助吗?
Thanks for the info!
that is not my question. I am looking for advise about the connection.
The SSD needs another and smaller connection than the HDD.
I could not find this connector and therefore I placed the question on the forum. I hope that some person can tell me what I need and where to get.
This generation Time Capsule came with SATA magnetic hard drive. Inexpensive SSDs with SATA connectors are widely available in 2.5 inch format (typically used in laptops). Initialize the SSD drive prior to insrall so that it is recognized. After install, the Time machine app will ask to format the drive.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 7,340
2条评论
Also, will the SSD even effect the speed of my backups or will it stay the same? I was hoping that it would make my backups faster
由 Strider 完成的
It won't hasten anything as you're bottlenecked by the connection interface from the logic board.
由 Haitham 完成的
