跳转到主内容
加入维修社区 - 创建账户
AirPort Time Capsule 是由 Apple 制造的无线路由器和网络附属存储 (NAS) 设备。A1409 型号是 2011 年 6 月发布的第四代 Time Capsule 改版。
Replacement HDD larger than 2 TB?
What is the largest HDD I can use in my AirPort Time Capsule 802.11n (4th Generation)?
Current HDD is causing problems and is running out of space (2tb) looking to put in a 3tb or 4tb if available.
Make and models recommended would be a great help too
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 17
6条评论
md032ll/a a1409
完成的
Hello
Has anyone tried to use wd red drives yes I am considering trying a 6tb red drive suggestions please ....thanks
完成的
i have used several wd red drives,,,very good drives
完成的
does it take SATA drives ? or is it IDE ? it’s pretty that is why i ask
完成的
Data works best didn’t use ide too outdated for my tastes good luck.
完成的
显示更多的1条评论
添加一条评论
8个答案
已选择的解决方案
Here'a a nice guide on how to do it: http://www.maclife.com/article/howtos/ho...
这个答案有帮助吗?
得分 10
2条评论:
This guide is basically ok. There are only two additions I would suggest:
1. Use a hair dryer to cautiously heat up the base rubber, and lift it up starting at one corner. This prevents the rubber from being ruptured.
2. Disconnect the inner fan cable from its socket. It is helpful to have the housing of your TC separated. Don't forget to reconnect! ;-)
完成的
Nice Solution .. great solution :)
完成的
添加一条评论
最有帮助的答案
Yes, you can. The A1409 contains a standard WDC Green 2TB HDD. I used the existing repair instructions to replace this with a WDC Green 4TB HDD - exactly the same except double the capacity. When the Time Capsule restarts you get an error message in Airport Utility saying the "Disk needs repair". Click the error message, then hit "Erase" and Airport Utility formats a 4TB partition on the new HDD.
这个答案有帮助吗?
得分 15
添加一条评论
Hello there...
Just replaced my 2tb drive with a WD 6tb NAS red. Works just fine.
Regards to all
Col
(aka VK2CRT)
这个答案有帮助吗?
得分 9
添加一条评论
I have the same model Time Capsule and I just upgraded the hard drive to a Seagate Enterprise Series 5TB, 7200 RPM drive. It's lightning fast and has plenty of storage.
这个答案有帮助吗?
得分 8
添加一条评论
Can anyone suggest the best hard drive to use to replace the original? How large a hard drive can I put in one of these? Thanks in advance!
这个答案有帮助吗?
得分 0
添加一条评论
A 6TB WD Gold WD6003FRYZ is working like charm. Only had to reformat the drive after replacement. Thanks for the HDD replacement guide.
这个答案有帮助吗?
得分 0
添加一条评论
Can I partition a Time Capsule ?
这个答案有帮助吗?
得分 0
添加一条评论
I replaced the stock HDD of WD30EZRS 3.0TB with Seagate 8TB IronWolf Pro ST8000NE001. My A1409 with 8TB HDD have worked fine~!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mockingbird1313 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 68
总计 35,320
