跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
20 个问题 查看全部
Is there a real way to enter DFU?
I have an old apple watch that was stored for a long time, now it doesn’t turn on, it gets stuck in a beating apple logo when connected, support sais there is no solution but a paid replacement. I found on internet an iBUS cable that claims to be a way to enter DFU mode so you are able to apply a full restore from the OS image. Do you know if it is real and if it works?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Yes, the iBus tool is what you will need to enter into DFU mode.
这个答案有帮助吗?
得分 3
4条评论:
@danj where can we get this tool?
完成的
Can I purchase the iBUS tool from iFixit?
完成的
完成的
I have an original Apple Watch with a corrupted iOS and I bought an iBus S1 to attempt a recovery. Unfortunately signed OS update files are no longer available, so as far as I can tell an update with iTunes is no longer possible.
The only alternative I've seen is to get a membership on the manufacturer's site, which then allows you to use their tools to update with (presumably) an unsigned file.
I bought mine used without a serial number so I can't register it, leaving me unable to use their tools and therefore unable to update my watch. It does, however, work great with iTunes if I only had a valid file to use.
完成的
添加一条评论
添加你的答案
raiman264 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 26
总计 482
