跳转到主内容
加入维修社区 - 创建账户
The Craig CMP801 is a windows tablet powered by a 1.83GHz Atom Z3735G Quad-Core CPU, has a 16GB storage and includes the following components: Bluetooth 4.0 version, HDM1 accessibility, SD slot, and 1GB RAM.
It wont turn on. It doesn't seem to be charging.
It won't turn on. It doesn't seem to be charging.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
JCorley Gray  start by checking your charger, your charging cable. Then check your connector and see if there is any lint etc occluding it and if the cable fits snug or if it is loose. If all of that checks out you will have to tear your tablet down and replace the battery. While you have it open you also want to check the charging port connector (solder joints etc.) Craig CMP801 Battery Replacement
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
JCorley Gray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 12
总计 383
