跳转到主内容
Repair information for the Asus F201E laptop. Released in November of 2012. Model number: F201E-KX034H.
8 个问题 查看全部
There is a possibility to change the Cpu of this laptop?
My cpu is intel celeron 847 which means to outdated and so bad in browsing and for gaming I just want to know that there is a possibility to change the Cpu of this laptop? Or just an hopeless
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
hi. i have a problem , i am using Asus X540M-GQ258T gives me problems when it comes to install games , so i just want to know that there could be a changei if i upgrade the RAM and the CPU of this lsptop?
完成的
Better to just upgrade to SSD drive.
完成的
添加一条评论
2个答案
最有帮助的答案
The CPU is soldered. You need a motherboard or rework experience to replace it.
这个答案有帮助吗?
得分 2
添加一条评论
The short answer is yes. According to ASUS website, F201E supports both Intel® Celeron® 847 Processor, GHz
and Intel® Celeron® 1007U Processor, GHz.
https://www.asus.com/in/Laptops/F201E/sp...
http://cpuboss.com/cpus/Intel-Celeron-84...
Hope my answer helps you.
这个答案有帮助吗?
得分 1
4条评论:
Ho @v3nuo,
Looking at this video it appears that the CPU is mounted on the board or is it the plug in type with no holding mechanism or screw to keep it in place?
Wondering if the specs just mean that it could come shipped with any of the CPU mentioned depending on whether you wanted to pay extra for it at the time.
完成的
@jayeff When he said change, I think he meant an upgrade, it does involve extra cost.
完成的
Hi @v3nuo ,
That's what I was wondering if it were possible.
Is the CPU actually soldered to the board, making it very hard to replace?
完成的
@jayeff If it's soldered, it's still possible, it involves more than extra cost, but I don't think it's worth as the device is too out-dated.
完成的
添加一条评论
添加你的答案
Paolo Aquino 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 6
总计 605
