跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
changed the screen of samsung s8+ but the phone isn't turning on
the phone was in a bad condition when I got it (smashed screen) so I decided to change the screen + the frame, ordered service pack and I got finished to move every component to the new frame.
however, the phone is still not turning on.
when I plug it to the battery, it vibrate once. still nothing. when I plug it to my computer it wont recognize it.
I struggled a bit with the vibrator motor when I took it off from the smashed screen… maybe it’s faking the vibrate and I need to change the battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Do you have the wireless charging coil installed? This is part of the black plastic mid frame that clips into the metal housing and on top of logic board.
由完成的
I do, I thought that was the problem so I installed it but it's still doing the same weird vibration and not turning on
由完成的
添加一条评论
2个答案
最有帮助的答案
@tom9 always have a plan when trying to repair devices you have no history on. Something Like the Samsung flowchart would be a good way to start. That way your troubleshooting is organized and not all over the place :-)
Right above U7002
这个答案有帮助吗?
得分 3
2条评论:
Bro, that flowchart file is amazing! Could I please ask where you got it from? Any chance you could share the full document please? Many thanks in advance! :D
由完成的
@Felipe Leal contact me by email. Address in my profile. Just click on my avatar.
由完成的
添加一条评论
It’s either that the battery is screwed and needs replacing, when you were replacing the screen you may of damaged the main circut board, or that the previous owner has done something to the phone that has caused such damage to occur. that’s either caused by an extreme impact or some accident that has something to do with liquid as damage can compromise the waterproofing.
I hope this is helpful! :-)
这个答案有帮助吗?
得分 1
2条评论:
I'm planning to change the battery and update if there's any change
If it's not helping, I can assume the board is damaged?
由完成的
@tom9 yep, if it doesn't show any sign of life after replacing the battery, there may be either something wrong with the circut board or a critical piece of hardware has failed
由完成的
添加一条评论
添加你的答案
Tom Doe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 1,084
