跳转到主内容
Model A1046 or A1095 / 1280x854 screen resolution
PowerBook doesnt start even with ac connected
powerbook doesnt start up. after it wasnt switched off for a few days and battery was (322 cycles ) pretty much dead since it was not connected to ac.
i didnt use the book for quite some time ever since.
one day ago surprisingly i could start it while ac connected and i ran fine.
i turned it off and switched it on severals hours later. it started without any problem again.
today i tried again, it doesnt start at all.... neither battery (wich doesnt show any green LEDs) , and neither with ac conncted.
what your recommondation?
a
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Tell us about the AC charger connector light please.
完成的
hello mayer
theindicator lights on ac are green. no green lights on the battery though.
today i found out abaout a PMU restart.
great, and it starts this way. but when i turn it off it cant be startet normally, so i do the PMU again and it then
starts again.
完成的
orderd new battery...thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
If the battery drains completely, sometimes these machines will not start with the AC adapter plugged in. After the battery get some charge it will start up. Of course the battery has to be able to take some charge. If your's is almost gone, it would behave as your is doing. Here's where to get a new one: http://store.fastmac.com/product_info.ph...
这个答案有帮助吗?
得分 2
1条评论:
I'D check the PRAM battery too...
完成的
添加一条评论
添加你的答案
Ren 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 790
