跳转到主内容
The Dodge Dakota (called the Ram Dakota for its final two years of production) is a mid-size pickup truck from Chrysler’s Ram division (formerly called the Dodge Truck division). The second-generation Dakota began development in 1991, though they were not introduced until 1996 for the 1997 model year.
71 个问题 查看全部
Location of blower resistor
I have removed the cowl and found the hole it is supposed to be located in, but I feel nothing inside the hole. I called the dealership and they told me I should see it again I see nothing inside the hole I feel nothing inside the hole. So please help me figure out the location of the part number RU479 I am trying to install in my Dakota sport.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
mommy_luvz_u it is easier if you post some good pictures of what you are looking at etc. That way we can see where you are at and can most likely provide you with some decent answers. 在已经存在的问题里加入图片
完成的
添加一条评论
2个答案
最有帮助的答案
Hi,
Has the blower motor ever worked?
If not, the resistor may have been removed and the harness connector pushed back in out of the way, due to some other problem. Just a thought.
Here’s a link to the relevant section from the 2000 Dakota Sport service repair manual
Scroll down on the page in the viewing box to find p.24-3 and p.24-25/26 to view the location of the blower resistor, and the necessary pre-requisite steps to remove and replace the resistor.
Here are some of the pages if you have problems.
(click on images to enlarge for better viewing)
Hopefully this is of some help.
这个答案有帮助吗?
得分 1
添加一条评论
remove dash (at least tilt it back) blower resistor located middle of windshield under dash
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mommy_luvz_u 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 68
