跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
iPhone X bootloop broken screen
For the first hour after i heavly broken the screen (i smashed the oled pannel underneath the glass, upon the logic board connections) the phone was fine, then it suddenly started to bootloop on the apple logo.
When connected to iTunes sometimes the boot reach the point when the phone gets identified (and gives a vibration), sometimes not
In recovery mode, trying to recover i get error 10 and 4013.
I already tried to open the phone and disconnect all the connectors except battery and lightning (no screen), but still bootloops when trying to identify using iTunes.
The phone charges (with the charging screen) and gets identified in recovery mode (and i get the connect to itunes on the broken screen), is there any way to diagnose?
Should i order a new screen or is the motherboard dead?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You should try another screen first. Error 10 is no big deal but error 4013 is. It usually means there is a communication problem between IC’s Maybe NAND, Baseband, CPU or eeproms it could be a cracked coil the list goes on and on. But a repairer would try a known good screen first on the IPhone X
这个答案有帮助吗?
得分 2
2条评论:
I just ordered a new screen, hoping is just that :) thx
完成的
how did you solve the problem please help I am facing error 10
完成的
添加一条评论
添加你的答案
Davide Schiavato 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 20
总计 463
