跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
260 个问题 查看全部
One of my USB C ports is not working, what’s the repair process?
Hi! So recently my MacBook randomly stopped working properly. One USB port is no longer working. No power or device works on that port. Every other port works perfectly fine. What’s the repair process to fix that si glue port?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Is the mate port working?
Does it seem to be loose?
完成的
Hi, sorry I'm not sure what is the mate port? It doesn't seem to be loose.
完成的
@Ayushmaan Ganotra - The mate is the one beside it. Each side has two ports. Lets call them Left and Right and A & B
Left Side: Port A - Port B
Right Side: Port A - Port B
Which one is giving you trouble?
完成的
Hi yeah the mate port does work. It's on the right side. When looking at the laptop it's the one closer to the trackpad.
完成的
添加一条评论
2个答案
最有帮助的答案
First step would be testing power and data lines of the Usb port..a multimeter would do for first ones and an oscilloscope would be needed for data lines, providing you have a good board to compare results with. Other than that you’d need a skilled repairer into component level repairs.
这个答案有帮助吗?
得分 2
1条评论:
A simpler way would be a simple USB-C power meter like this one: Satechi USB-C Power Meter
完成的
添加一条评论
OK thats a good sign! So the port connector is likely the problem Vs the driver chip behind it on the logic board its self (both ports would have been effected)
Here’s the needed part: MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board
You’ll need to first follow this guide to get the bottom cover off: 2016年末带 Touch Bar 的15寸 MacBook Pro 底壳更换 Then you’ll need to take the logic board out to gain access to the two screws holding the connector core. While it looks daunting its not too bad! Just carefully disconnect the ribbon cables which are held by the metal covers and the mount screws. Use the 配备Touch Bar的15英寸MacBook Pro拆解 to help you see when everything is. Once the board is out you can gain access to the screws.
MacBook Pro Retina (A1706 & A1707 Late 2016-2017) USB-C Board图片
产品
$19.99
MacBook Pro 15" Touch Bar Late 2016图片
指南
难度:
中等
MacBook Pro 15" Touch Bar Late 2016 底壳图片
指南
难度:
中等
5 - 10 minutes
这个答案有帮助吗?
得分 1
1条评论:
Hi. This is super helpful! I'll give you an update on the situation once I get the parts.
完成的
添加一条评论
添加你的答案
Ayushmaan Ganotra 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,822
