跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
How to solder a power button switch to a laptop motherboard
ok so i have a 2007 macbook motherboard im gonna use it with a portable monitor so one thing i dont have a power button and some ppl said to me to solder a switch/button on the motherboard but i dont know where to solder one but thanks i appricaite the help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
For this model I believe the power on pads (marked with a power icon) are located below the fan:
You can just solder a basic button & two wires to those and you’re set.
这个答案有帮助吗?
得分 1
3条评论:
ok i never did this before lol so where could i get wires and what color could i use wires from a phone charger so lol im just trying to understand this correctly ok so i need wires and a button and then i need to solder the wires to the motherboard and then to the button and im all set
完成的
I'm just thinking you get a [button like this](https://www.amazon.com/Twidec-Normal-Mom...) and attach each wire to a pad. A bit pricey, too bad RadioShack went out of business lol — you've gotta be careful though, make sure you don't short out anything else on the board, it's small stuff you're working with.
完成的
@jonaharagon ok where does the red and black wire go on the pads or does it matter which side and also what side on the switch thanks
完成的
添加一条评论
添加你的答案
Kenneth shawn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 871
