跳转到主内容
Repair guides and disassembly information for Microsoft's third-gen Surface Laptop, released in October of 2019.
27 个问题 查看全部
What kind of SSD?
What kind of SSD does the Surface Laptop 3 support? 42mm? is it NVME?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
最有帮助的答案
Hi @vishalpmehta ,
according to Microsoft representatives, it’s an M.2 NVMe SSD. But as they said, it’s not removable by “user” and you need to search “skilled technician” to remove it. I don’t know, the time will show.
You can read the full article on the pcworld.com
这个答案有帮助吗?
得分 2
2条评论:
iFixit just published their teardown! Microsoft Surface Laptop 3 (15-inch) Teardown If you jump to Step 6 you can see it. As for possible options Microsoft is using the smallest M.2 size: 2230 which is not a popular size presently.
You also have a chicken and egg problem! As you will need to figure out how to clone the OS and apps over to the replacement drive.
Give it some time, as its just become available. I'm sure someone will figure it out.
完成的
I don't see why you couldn't just boot from a USB pre-loaded with the Surface Laptop 3 OS and firmware etc after installing a new drive?
完成的
添加一条评论
Solid State Drives - SSD PCIe M.2 2230 512GB Client SSD
这个答案有帮助吗?
得分 1
添加一条评论
SSD PCIe M.2 2230 256GB, easy to replace 4 screws from back lid and one form SSD
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vishal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 20
总计 1,853
