跳转到主内容
加入维修社区 - 创建账户
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
Poor GPS quality after screen replacement
I have recently replace the display of an iPhone X after it receive an hammer, now the GPS present issue, is really inaccurate and doesn’t work well with navigator apps but a few times it works fine.
I would like to know if it cause by the screen replacement or by something else and possible solution
Thk
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
Was this little gold piece placed back in step 22 of this guide?
iPhone X 屏幕面板更换
这个答案有帮助吗?
得分 2
3条评论:
Yes, I'm gonna check if I place it in the correct position place as show in the pictures, in case is not in the correct place can that be the issue ?
完成的
Not 100% sure but those grounding pins do have an affect on the antenna strength as the housing is essentially an antenna.
完成的
Well I check and the little gold piece was in the right place, and still having issue i try with GPS status to check the accuracy and while my iPhone XS can have a 5mt accuracy the iphone X doesn't go lower then 32mt.
Also i try reset location and network ecc. like in some guides
完成的
添加一条评论
i have the same issue…..
thought about replacing the antenna but…. is the WiFi antenna is the one i should replace? (its at the bottom of the phone and has nothing to do with the screen replacement procedure…)
i cant find any GPS antenna….
这个答案有帮助吗?
得分 0
1条评论:
I have the same problem after doing a screen replacement - GPS worked fine before screen cracked from being dropped. I did the screen replace and now no GPS. I don't think replacing the wifi antenna will help GPS reception. I called an ifix store and they said GPS is in the motherboard. Going to try factory reset next.
完成的
添加一条评论
添加你的答案
Daniele Zamboni 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 29
总计 5,987
