跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 个问题 查看全部
iPad Air 2 wont turn on
iPad Air 2 wont turn on or charge, there is absolutely no signs of life. i measured it via lightning caple to input voltage about 5.20 volts but not any current, it says 0.00amps even after charging overnight. Tried hard resetting multible times, no luck. iTunes doesn’t recognize it at all.
I really want to see if i can fix the problem without taking it apart, since i dont want to risk cracking the expensive display/digitizer combo.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Maybe you have a bad dock charging connector??
Is the charging cable loose when it is inserted in to the dock
Has you do not want take apart the iPad ?/ bu what you are saying you will have to
The Thristar tester would give you a good idea what is faulty but not 100% full proof
Link
https://www.repairsuniverse.com/products...
这个答案有帮助吗?
得分 1
1条评论:
it might just be that the battery is stone dead and needs replacement. the lightning connector fits snug and perfect within the charging port without any wiggle room. i guess i will have to take it apart and start testing.
完成的
添加一条评论
添加你的答案
Tubbe Lenbroch 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 76
