跳转到主内容
The Asus Zenbook UX301LA is an Ultrabook with a 13.3-inch IPS display. It was released in November 2013 as a part of Intel's Ultrabook line.
16 个问题 查看全部
Will a replacement battery for a UX301LA work in a UX533F zenbook?
I can not find any information in the UX533F. The model mentioned in this question looks the closest to the zenbook I am looking for a battery for. Wondering if they have the same battery.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
depends does it fit the port for the battery and is it same voltage and mwh output?
完成的
Der Anschluß zum Netzteil wurde schon ersetzt.
完成的
@Ayden Aldrich
完成的
@Ayden Aldrich The connection to the power supply has already been replaced.
完成的
添加一条评论
1个答案
Hi @waydeph
according the specifications,
UX301LA is having C32N1305 battery, which is not fully compatible with UX533F (voltage and capacity are different). It’s compatible with Zenbook UX301LA Zenbook UX301LA-C4003H Zenbook UX301LA4500. If you want to search for compatible battery, please disassemble your laptop and check manually, what’s written on it. When you will get a PN, you can easily search for the part on the Amazon, etc.
Note:
I’ve only found, that your laptop is compatible with 0B200-03120100, 0B20003120100, C41N1814, C41PPEH batteries. The original battery is supposed to be NASC41PPEH4800B4.
For the better know, check it manually.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Wayde Hall 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 5
总计 168
