跳转到主内容
修复Nintendo Switch Joy-Con控制器的指南和信息。
167 个问题 查看全部
My Y tip screw is stripped! What do I do?
I was trying to fix my drift problem in my right joycon controller when I stripped the screw when trying to open the back plate! The screw is in a little hole and I’ve tried many things like the rubber band technique and super glue but I don’t know what to do to remove it. Unfortunately, I live outside the US (in Thailand) and there are no Joycon repair stores (let alone nintendo stores) near me. However I am visiting the US this winter and heard that Nintendo is no longer charging a fee when repairing the drift issue in joycons, but I’m not sure if I’ll still be charged due to the stripped screw? If you have any information (about the screw or the repair in America) please respond :)
thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
yes, Nintendo is giving free repairs. I sent my joy-cons and one had a missing A button and when they returned my joy-con had the button back. all you have to do to send the package is to go to Nintendo support and click on the repairs, you will have to put some information, then you will get an email with the ups label with your information on it then you will have to put your faulty joy-con in a plastic bag for protection. It will take a couple of weeks for it to return. Hopefully, I helped you with your problem.
这个答案有帮助吗?
得分 2
2条评论:
Have it sent to the USA address you will be at.
完成的
Also, make sure someone is at home to get the package because they could steal it.
完成的
添加一条评论
I’m hoping for a better answer, but I bought a new shell and just broke the back piece off and replaced it with the old back shell… Hope there’s a better solution out there
这个答案有帮助吗?
得分 0
1条评论:
something like EZ Grip Aircraft Grade Friction Drops (search term for other brands is friction drops)
完成的
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 4,663
