跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Can you add a 2nd HDD to the $799 Mac Mini?
I've looked at the teardown and I must ask if anyone knows if you can add a 2nd HD to the $799 Mac Mini. The reason I ask is because you cannot get the AMD Radeon HD 6630M Graphics card and a second hard drive.
If I buy a $799 Mac Mini and choose to add a second HDD will there still be room or does the Radeon HD 6630M card get in the way?
I want the server version, but you have no choice on graphics cards. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I can confirm I was able to install a 2nd drive in mine just fine. In fact I replaced the stock 500G drive and installed two SAMSUNG Spinpoint M8 HN-M101MBB 1TB 5400 RPM 8MB Cache 2.5" SATA 3.0Gb/s Internal Notebook Hard Drive -Bare Drive from newegg.com.
这个答案有帮助吗?
得分 2
2条评论:
+ what cabling did you use?
完成的
I used the cable sold by iFixit.com, and the original Apple cable. I did peel off the black plastic from Apple's drive and transfer it to the new drive. Don't want any shorting.
完成的
添加一条评论
As far as I know there's no definitive answer yet. I guess we're waiting for someone to actually obtain the required cable and successfully fit a second drive in a 2011 mini with Radeon 6630M. It certainly looked like there was room in mine when I fitted my SSD the other day. It had the space under the HD just like in the teardown of the Intel-graphics-only mini. As soon as it's confirmed possible I'll be adding a second drive to mine for Windows.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shane Whitford 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 2,210
