跳转到主内容
Model A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 or 3.8 GHz Core i5 or 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K display. Refer to the older iMac Intel 27" Retina 5K Display (Late 2014 & 2015) guides as the system is very similar.
286 个问题 查看全部
CPU Upgrade Issue - No power
I decided to upgrade my 2017 iMac 27 in two parts this weekend: NVMe and SSD first, then CPU.
First part: 970 EVO NVMe with heatsink installed. Recognized @ Link x4 and great speed. SSD installed and MacOS Catalina reinstalled. Very happy so far.
Second part, a day after: Removed CPU, installed i7-7700k. Struggled a bit with heatsink like everyone it seems. But once done I felt confident that everything was done right, so I re-assembled everything. But the power switch didn't trigger anything!
  • LED 1 is on as soon as I connect the iMac to the external power cord.
  • Power switch cable seems intact and connected to PSU. PSU and logic board cables all disconnected/reconnected with great care and seem intact.
  • Tried to short both power switch pin to start up the Mac. Nothing happened.
Does anyone have any suggestions or comments on what the problem may be?
  • I've ordered a new PSU for safe measure. I can't find a spare power switch button (the only part available that has it is an entire empty housing!).
  • Can't find a spare power supply control cable (between PSU and Logic board) for a 2017 iMac. But there are some for the 2011-2013 iMac which looks the same as for the 2017 version.
Tempted to order that. Does anyone know if the 2013 and 2017 use the same power control cable?
After discussing with friends, one plausible explanation could be that my CPU upgrade went bad. Such as static electricity frying the Logic board. Or the CPU is bad. Even though I've been careful all the way. However, if I understand the explanations regarding the logic board LEDs function, it seems that not even having the LED 2 or 3 on would mean my issue isn't yet entirely related to the Logic board or the CPU. Anyone can comment on this?
I would be very grateful for any suggestions (at least it'll boost my morale, as right now if the new PSU doesn't work, I would have probably to sell the iMac for parts!!)
Thanks
Seb
Update (10/15/2019)
Just received the new PSU (see picture). Installed carefully (making sure I discharge any static electricity from my hands prior). Reconnected all wires, after inspecting them (see picture). And unfortunately I have the same result: the power switch, which seems to be 100% intact (see pictures), doesn’t trigger any response. Fan doesn’t spin. No second LED.
Could it be the main power cable socket (buried under the bottom bezel of the imac housing)??
Any suggestions welcomed!
Update (10/15/2019)
Disassembled the Mac again. Look very carefully for damaged cables, or sockets… None found! Took a picture of the wires coming from the main power socket (see below). Everything looks fully functional.
Could this be a back Logic Board??
Update (10/16/2019)
I can finally breath: Removed the new CPU, installed the old CPU and I’ve got the board to boot up. Did not perform a full reboot with the LCD on. I will make another attempt at upgrading tomorrow with another CPU, so I had only the PSU and Logic board mounted.
Is this a Bad CPU or it wasn’t mounted right, I can’t say for sure. But the Fan started to spin at max speed without stopping, so that got me thinking and decided to go for the i7-7700 instead of the 7700k!
Now, I got to improve my tension spring loading technique. I concur with others that the tension produced by this spring is excessive (Judging from the residue of thermal paste which had been completely squeezed out to the sides when I removed the CPU). So I’ve kept a more important gap between the mounting spring and the logic board, than what I had originally measured (<1mm). See pictures.
Hopefully my next post will be about completing this job… Wish me luck.
Update (10/17/2019)
Final update: Finally got the system to work.
How: The short answer is you have to unbend the metal spring underneath the CPU!
There is way too much tension in this spring, this put so much strain on the CPU that it bends it. Some pins are then no longer connected. When the LED 1 or 1-2 lit up and nothing more it just means that.
I’ve tried a i7-7700k twice, reinstalled the i5-7600, then tried and kept a i7-7700 finally. So I’ve got plenty of trials to figure all this out.
I will now answer questions :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
6条评论
So does your logic board work with all 3 cpus? My logic board doesn't work now that I upgraded to an i7 4771 on my 2013 imac.
完成的
The issue is mounting the CPU is a bear! @sebmcadet issue was the tension of the spring and mounting the screws without distorting the CPU chip. This is where the method of tightening the screws is tricky! Just like replacing a tire you can't focus your effort on one screw screwing it in all the way before you do the others otherwise your wheel won't be mounted properly. You need to use a cris-cross pattern slowly tightening each screw down so the pressure is even as you go! Reducing the spring tension is a bit risky! The other risk is damaging the CPU chip as well if stressed
The other issue is having the CPU shift on you so you damage the socket pins!
完成的
i7-7700K works well on my 27" 2017 (I've replaced the i5-7500 3.4Ghz)
完成的
I have the same problem, the cpu edges bent a bit, but what exactly did you do to make it turn on? Until where do you have to tighten the 4 screws? Please help me
完成的
Hey, look at my post down at the bottom, that's how I did it... need probably a bit of luck, too :-)
完成的
显示更多的1条评论
添加一条评论
4个答案
已选择的解决方案
Sadly, you need to roll back your CPU to check your logic board. I suspect you either have a bad chip or in the process you damaged one of the socket pins or lastly, mis-aligned the chip.
这个答案有帮助吗?
得分 2
6条评论:
I was actually thinking of doing that. Just removed the Logic board and been staring at it for while.
Tightening the heatsink on this board was not trivial. Can the logic board pins be visually checked for damage, and what to look for? Mis-aligned seems impossible as you have two notches that would prevent it, correct?
--- Would love to have a bad chip. But 1. I may have touched the CPU's underneath and 2. When trying to screw the heatsink the spring plate underneath the board was sliding in all directions. Will post again when I re-install and test the board. Thanks for your prompt reply.
完成的
@danj Just posted an update above!
完成的
Reduce the amount of thermal paste! You only need a little bit so a film across the whole chip surface is covered.
完成的
Thanks Dan. Yes, I figured that out. It gets all squished to the sides everytime. So i've used less and less.
完成的
Having the exact same issue after installing 7700. Mac looks dead. Roll back to old cpu and system boots. How much did you end up bending the rear support spring and did you modify the screw down distance?
Cheers
完成的
显示更多的1条评论
添加一条评论
Hi, I’ve already f**** up 2 CPU’s because of that stupid spring. An i7-7700k and the original CPU. How bent were the CPU’s and can you still use them, even if they are slightly bent? Not looking forward at playing another 200-300 bucks.
Thanks in advance.
-Alwin
这个答案有帮助吗?
得分 1
3条评论:
You also mention to bend the spring on the underside of the logic board. By how much?
完成的
I bent mine back just by using my fingers. Tried it fingers crossed, didn't work at first, was just about to start cursing when - with power on (don't try this at home) I just loosened the screws just another bit. And it turned on, would you believe it! So yes, it can be bent back. Use your fingers and look down the edges to see if they're straight, and then be very careful on installing it back if that's possible at all. Personally, I'd try next time to turn the spring around and see how that works out.
完成的
The socket contacts are very fragile! It’s easy to snap them off. If you do hopefully it’s a grounding path which you might sneak by. If not you’re SoL!
Softening the pressure spring can help but going to far can create errors when running as the chip heats up it can shift and the moment of loss connection can corrupt things.
完成的
添加一条评论
I’m also having a similar issue, but I’m upgrading from a 7700K to 9900K. macOS DOES recognize it as a processor since it’s the same processor in their 2019 iMac, but I can’t get it to boot. I’m going to run some experiments and see if it’s the pins on the socket itself.
这个答案有帮助吗?
得分 1
3条评论:
Any update? Thanks!
完成的
The computer is still gutted, but I did some digging and while the SOCKET is identical from the 7700K & the 9900K, but the CHIPSET is different. Translation: While the i9 will physically fit, it won't connect. The pins mark to different readouts. I wish I knew this before, but the documentation on these iMac upgrades are extremely fragmented.
完成的
@figtreecinemas - Sorry, the micro code within the system firmware messed you up. Basically, you are limited on what Apple used in the given run. To go beyond that you will need to review the given Intel chip to see what the family is and the chip you are thinking on using only chips within the given chip family will work as they share the same micro code.
完成的
添加一条评论
Hi!
I have the same problem, my 2019 5k iMac with CPU and nvme SSD upgrade won't turn on but the fan is spinning and two led lights turned on too (please see attached image/s).
Anyone have an idea what does this mean? What did I miss?
Update (10/12/23)
Worse happened. One led is just working after undoing everything such as placing the original CPU and PCIE SSD.
这个答案有帮助吗?
得分 0
4条评论:
Well looking at this thread, it seems plausible that the most common error is too tight screws on the attachment spring of the CPU, which then results in bending. I unscrewed mine while power was on until it finally came alive - but I can't recommend that. Safer than that is just unscrewing it, looking for bent edges and if so, carefully bending them back, and then tightening the screws as gently as possible - which is hard because the spring is so freaking tough.
完成的
I shall try it tomorrow and will post an update. I just can't understand the meaning of led lights and its meaning.
完成的
Still the same. It won't turn on.
完成的
I took my unit at the service center and they said that the IC TERMINAL on the logic board needs replacement. I could have agreed to have them fix but they are charging a lot of money!
Is there a tutorial on how to replace the IC terminal on the logic board?
完成的
添加一条评论
添加你的答案
Sebastien Cadet 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 36
总计 1,784
