difference between lm270wg1(sd)(f1) and lm270wg1(sd)(f2) lcd
or can I use another type, my screen is black but it is not the graphics module. (shining with a strong lamp I see the icons)
Thanks for any solution
Update (10/15/2019)
So, i must replace the whole motherboard (
). Is there and layout of the connector (power)?
1条评论
Sadly, your logic board does need repairs. Replacing it would be anther option.
If you had opened the system to alter your drives and you encountered this afterwards I would also check the power cable.
由 Dan 完成的
