跳转到主内容
加入维修社区 - 创建账户
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
Getting S.M.A.R.T. errors on Apple SSD disk.
Hi,
I have this problem: My Fusion Drive in my Mac Mini Late 2012 is failing. I have S.M.A.R.T. errors on the Apple SSD drive.
So I have decided to upgrade to an 1TB SSD Samsung 860 QVO. But, I have many errors. I can't restore from TimeMachine and I can't reinstall from internet. On reboot I have crash.
So can you give any help? It seems that my Mac Mini is searching for 2HD (Fusion) and not only one... so gives me errors. Is there a solution?
Bye
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
First you need to put your system back to its original config with the HDD and the SSD installed. Then you will need to break the Fusion Drive set so you can take the drive out. Follow this guide Split Your Fusion Drive Apart
Once you’ve done that you can then reconfigure your drives.
Are you sure you’ve identified the correct drive? This system has two 2.5” drives which look the same! So make sure you’ve ID’ed the correct drive.
Mac Mini 2012晚期硬碟更換 A common issue is the ribbon cables fail so you may not have a bad drive but a bad cable. That can explain your OS install errors.
这个答案有帮助吗?
得分 1
1条评论:
Thank you. I have Mojave on my macmini so your guide is not for me in all steps.
In Terminal i have to digit different commans to split my Fusion… but in general this answer solves the problem.
Bye
完成的
添加一条评论
添加你的答案
fabio 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 344
