Random changing dot array on LCD
I'm running a diagnostic on this Samsung Tab and there’s this dot array that will flash every 2 seconds and change to a different pattern everytime. Has anyone seen this before?
EDIT: So far I have tried checking all internal connections to see if any are loose. There is no sign of any water damage, dust, or any other environmental damage. Just completed a software rewrite (AP and BL) through ODIN and ended up with the same dots. The dots do not show up when the device is on the recovery mode screen.
Hi @refurbpro ,
have you checked another version of FW?
由 Lucas 完成的
This is the exact package I used to write the software:
https://www.sammobile.com/samsung/galaxy...
由 Jeff 完成的
