跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
touch is not working
My iPhone 7 fell off of my bed and now the touch screen doesn’t work. Is there a cable that just fell off or is it something bigger??
Update (10/08/2019)
thank you guys, I will try taking it apart again, I was messing in it a few weeks ago so I will check it out
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I can think of a few troubleshooting options you can try. First you will need to get tools to take apart the phones display. But be careful the ribbon connecting the LCD to the motherboard. I that ribbon is ripped we don’t want to damage it any farther. The problem could be the ribbons {IF} that is the problem you got off the hook all you do replace them. If the ribbon is fine no tears or any thing indicating it has been damaged. Then the LCD and screen you will have to replace that.
这个答案有帮助吗?
得分 0
添加一条评论
Hi @mrmime
Try a simple hard reset first. Simply hold the POWER and VOL DOWN buttons for 10 seconds until the phone restarts.
If you are still having issues, it could be a damaged screen assembly. If you have opened the device before, it is possible that the screen connector came loose and a simple reconnect to the logic board will fix the problem.
Replace a screen compatible with iPhone 7. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch 750 x 1334 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, and LCD Shield Plate.图片
产品
iPhone 7 Screen
$54.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Elias Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 87
