跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
1525 个问题 查看全部
Buggy touch after water damage
Hey all. On Tuesday I was at a pool while on vacation and dropped my iPhone 6 Plus in the pool for just a second. I took it out turned it on a few times (big mistake, I know) but it wasn’t working. I didn’t have any tools with me so I wasn’t able to open it up until last night (Sunday). I cleaned the logic board with 99% Isopropyl alcohol, let it sit overnight then tried it again this morning. Everything worked, the phone turned on, but the touch on the screen was not working properly. Is this a board level problem or will I be completely fine if I just buy a new screen? Thank you all so much
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There are three potential issues here, one relevant to the liquid damage, the second to the fall itself and the third to the relatively common touch failure on the 6 plus, which is often associated with falls and flexing. I see no chances to procede with troubleshooting without a known good screen, but on the other hand, chances you may already have or will have other issues down the road should be taken into account. Not an easy decision maybe, but you’re the only one who can take it.
这个答案有帮助吗?
得分 3
4条评论:
So would you recommend I buy a new screen and try it out from there?
完成的
Well, I don't see how you could progress further without known good parts. I would also recommend to avoid practicing with board repair on your phone..world is full of cheap boards for spares to practice on.
完成的
@arbaman Thanks. I mean if the phone is already broken, I may as well try, right?
完成的
@jacobpie Final decision is of course yours, mine is just an opinion :)
完成的
添加一条评论
In general I find that touch issues are board related (especially after water damage). I’d recommend connecting a known good screen and testing that to see if the problems persist.
You might also want to take a look at the components on the board and see if any are corroded or discoloured. Check especially the Meson (U2402) and Cumulus (U2401) chips and the lines and components associated with them for damage.
Hope this helps!
这个答案有帮助吗?
得分 1
4条评论:
Two or three of the chips are a bit discolored (almost like a small rainbow ring at the edge.) This is my first board level repair. How do I check the chips?
完成的
@jacobpie You'll need a schematic of your board to know which components are on which lines. Find the lines that have contacts in those chips I mentioned before and check them with a multimeter to ensure the lines don't have shorts
完成的
@codyauch Thanks man. Do you know of any resources where I can learn to do these repairs?
完成的
@jacobpie Youtube is always a good resource, although I'm not sure if you'll be able to find specific videos on your exact problem, but you'll at least learn the general techniques. Checking out iPad Rehab's videos would be a good place to start
完成的
添加一条评论
添加你的答案
Jacob Pieczynski 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 58
