跳转到主内容
Problem with installation of panther ox
I canot install the mac ox panther 10.3. when i insert the cd it will start to run and i can see the apple logo, after some that i can see only s symbol a zero and a cross line it like do not enter symbol. any body can help me for solving this problem. I am using the original BLACK installation apple cd.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you have the iBook G4 (Mid 2005), it uses Mac OS X 10.4
Please give the last three figures of your serial number so we know exactly which machine you have. Also, how much RAM do you have and how much free hard drive space?
这个答案有帮助吗?
得分 2
10条评论:
I have ibook g4 12" 800MHz. iI have changed with a new hard drive. I dont know the serial number. i dont have any papers with me. Where i can see the serial number. please help me.
完成的
i have 512 ram in ibook G4
完成的
You need to format the drive before you can install a system. Start up from your system installation disk, "C" key. Go to the second screen pull down menu to Utilities > Disk Utility. Select your drive in the left hand column. Format it Mac OS Extended. With disk utilities and continue with your system installation.
完成的
I hold the C key then i can see the apple logo for some time and later i see the symol one circle and one slash inside it. "O \" then how can go to the utility, can u please explain step by step.
完成的
The retail version of 10.3 was black and had three disks. You machine should have had a gray disk that came with it. Try the gray disk.
完成的
显示更多的5条评论
添加一条评论
添加你的答案
paulykjoseph 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 722
