跳转到主内容
于2016年3月上市。型号 SM-G930V。
425 个问题 查看全部
How do I orient the new battery back seal?
My Samsung Galaxy S7’s screen went 1/2 gray and restore was impossible. I discovered that the problem is a bad chip solder junction in the motherboard and successfully replaced it and the phone works well now,
HOWEVER:
I messed up replacing the battery/back seal gasket. How do I figure out which way that seal is oriented, the manufacturer refused to answer my question.
Also, how do I apply that seal without it coming back off while I try to peel off the clear sheet it is mounted on. I went through two of them with no success. I want to do this right this time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
No One can help me?
完成的
@drhoo I think there may be some confusion as what you are looking for. Post some images and point out to us what seal you have etc.
完成的
添加一条评论
1个答案
There’s a guide to install the adhesive here.
这个答案有帮助吗?
得分 0
3条评论:
That doesn’t tell me which way to orient the seal, there are two ways it could go on, one end or the other on the top of the phone. I’ll post a photo of the seals tomorrow. The seal maker won’t answer my question and no guide says how to orient the seal.
完成的
How can I go about posting a photo of the seal product here, I can't find an upload photo link? Also, I bought the seal on Amazon, but the one in the photo on Amazon is not the product they sent, I think it's just s stock photo.
完成的
I think I see how to post image, with daylight tomorrow I will post a photo. My problem is figuring out what side of the seal goes on top and which goes on the bottom.
完成的
添加一条评论
添加你的答案
Marco 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 46
