跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 个问题 查看全部
iMac mid 2011 black screen on boot
I opened up my iMac mid 2011 21.5 to change the HDD to an SSD.
Now all I get is a black screen after chime on boot. I’ve tried resetting PRAM, ensuring all 4 cables are seated correctly (the LVDS connection is a bit loose but is in), all 4 diagnostics LEDs come on and stay on.
I changed back to the original HDD, I’ve cleaned all the dust out…but still no luck.
Anybody got any other ideas? Thanks
Update (10/03/2019)
Oh, and I can’t see any icons when shining a torch on the screen.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Check your V Sync cable is not damaged first.
Sounds like your LED driver board has failed. This can happen if you plug in the LVDS cable backwards! Take a look just below the LVDS connector on the logic board are the components burnt?
A loose connector also implies you pulled on it a bit so the connection is not tight. You may need to replace it.
Here’s how to take the LED Driver board out to inspect it as well iMac Intel 21.5" EMC 2428 LED Driver Board Replacement. Compare it to the images here iMac Intel 21.5" EMC 2428 LED Driver Board If you see any burnt areas you’ll need to replace it.
iMac Intel 21.5" EMC 2428 LED Driver Board图片
产品
$29.99
这个答案有帮助吗?
得分 1
1条评论:
Thanks Dan. None of the components appear burnt. So, will have to a new cable I think.
完成的
添加一条评论
添加你的答案
Simon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 113
