跳转到主内容
这里有各种关于P10维修指导
48 个问题 查看全部
Touch screen can't register taps on both sides after replacement
I have changed the display and the touchscreen of the phone. Now the left and the right sides of the touch screen can not register taps, but they can register slides.
I tested factory resetting the phone. Doesn’t work.
Is it possible that the changed display is not original or faulty?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
idolism  absolutely possible. If your digitizer does not respond etc., double check your work and make sure everything is connected right. If so, replace the digitizer once more since it is possible you have a bad part.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
idolism 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 95
