跳转到主内容
The Google Pixel is Google's first flagship phone, released on October 20, 2016. The 5-inch AMOLED display device comes with 32 and 128 GB storage options and is available in three colors; Very Silver, Quite Black, and Really Blue.
104 个问题 查看全部
Phone does nothing after battery replacement.
I bought the kit from ifixit to replace the battery on my pixel that was having charging issues. Everything went smoothly after I got the iopener to the right temperature, however after reassembly the phone doesn’t do anything. I can’t tell if it is charging or not (95% sure the screen was not damaged in the process), sadly I cannot call it to test it out otherwise since this was a backup phone I was going to after a main-board failure on my primary phone.
Is it possible to have gotten a bad battery in my kit, or is there another way to check screen health without going through finding one to purchase?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @curds301
Keep it on the charger for at least 30 minutes. Really dead batteries can take a while to charge for the first time. If you do not see any picture after 1 hour, it is definitely a bad LCD.
这个答案有帮助吗?
得分 0
4条评论:
I have tried leaving it plugged in, and no luck. There's no apparent damage to the screen that I can see. Is it common for the screen to stop working without visible damage?
完成的
It's not common but it is possible. Try to get one with a good return policy in case there is some other type of damage.
完成的
Any recommendations on a vendor? Seems ifixit has everything except the screen up for sale.
Edit: I found a vendor that has just the screens. Thanks for the help.
完成的
Glad you found something that will work! I've used this supplier a lot in the past and been happy with part quality and return policy:
https://www.mobilesentrix.com/replacemen...
完成的
添加一条评论
添加你的答案
Chris Hart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 101
