跳转到主内容
苹果Magic Mouse鼠标是由苹果公司制造和销售的多点触控鼠标。它于2009年10月20日首次公布和销售。
52 个问题 查看全部
Can I replace the laser bulb?
Everything is working on my Magic Mouse but the laser sensor, itself. I can gesture, scroll, right click, double-click to select a word. BUT the laser no longer comes on, so I can't move the pointer. Can I replace the laser?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
1条评论
can you explain me in detail that how you fixed it kaath9?
完成的
添加一条评论
2个答案
已选择的解决方案
I've never seen this part fail. I would suspect a failed solder joint. Of course if it is less than a year old, get a warranty replacement from Apple. If not, I'd tear it down and see if I could spot the problem. Here's the teardown: Magic Mouse Teardown
这个答案有帮助吗?
得分 4
5条评论:
You're right mayer, mine wasn't working well, only clicks and movements but no cursor moving. Once opened, I've heater the laser pinouts with a soldering iron and it's working well now. The problem now is to fix the batteries plugs. In order to disassemble properly, we need to cut 2 plastic pieces who maintain the metallic rounded batteries plugs on the frame
完成的
Can I solder without removing the capacitive sensor ribbon nor the battery case? @kospeia Did you achieve to do it?
完成的
What Part of the mouse do you solder once you open it up?
完成的
Asher Solder the place where you no longer have continuity.
完成的
Thanks Mayer
完成的
添加一条评论
I had the same problem! After several attempts, I tried to push the lens with a pencil eraser, now it works fine
这个答案有帮助吗?
得分 0
3条评论:
It makes me laugh, this is ifixit.
完成的
Hello fabrizio,
Did you just press it up, without opening the mouse?
Thanks in advance!
完成的
Hello Antonio, yes, you can do it without opening..... but ... the operation did not last much for me :-(
I think at this point that you have to open it and solder contacts with a soldering iron!
完成的
添加一条评论
添加你的答案
kaath9 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 31
总计 16,858
