跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for your LG TV.
Home menu display problem
Hi!
I have a LG Smart TV with a display problem but only on the main menu and options. No problem on the image coming from hmdi and other. Just the menu image that overlaps. If I test the image on the settings I can't spot anything problematic.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Hi!
Yes, it has the lastest firmware.
No. It only shows lines when there are LG elements on the screen, like options, settings, subtitles (if they are run from the TV, and not imbedded in the image), etc. Lines, always have the tendency to go to the upper left corner.
The picture diagnosis from the TV settings shows no problem.
完成的
Perhaps the panel is getting bad.. But I'm not sure. Maybe someone else here knows exactly what it is. How old is the TV ? And do you know the exact model you have?
完成的
The TV has less than 3 years old.
Model: 55UH615V-ZB
完成的
Hello Did you get a solution for this problem? as I am now facing the same problem and cannot find out a solution. Thank you
完成的
Hi Serge. Unfortunately no, I didn't find a solution. I have the firmware up to date, I have no clue what's going on :(
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
Did you already installed the newest firmware? And is it also showing the lines when the screen is entirely black? Any Possibility to run diagnostics or something ?
这个答案有帮助吗?
得分 1
1条评论:
Q: Did you already installed the newest firmware?
A: Yes
Q: Is it also showing the lines when the screen is entirely black?
A: No
Q: Any Possibility to run diagnostics or something ?
A: I run the internal image diagnostics from the TV, no problems detected
完成的
添加一条评论
添加你的答案
Aloi25 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 485
